MK1MAD
alternator conversion
evening chaps ..think this might of been on the forum before ?if you can please put on to it great ..if not help is needed converting my mk1 dynamo to alt but what do I do with the wires from the reg box ????
cheers norm
Posted 20 August 2015 - 03:56 AM
The general rule of thumb is at the reg box, all the thick wires you join together and there are usually two thin wires join those two to each other. The earth wire is not needed as you are not using the reg box, so tape it up/cut it off. The alternator has its own regulator so the original box is now redundant.
big thanks for that
fan belt and alternator fitting in the morning
broom broom
Maybe a bit thick here but I have two brown yellows together going to D and a green and a brown together going to B and one green and brown going to F
Get that the thick wires join together but what about the thin wire going to F
Cheers
Edited by NORM1
Cheers
the two thin ones join together
that's it all done many thanks for everyone's help :cheers:
:thumbup: nice one Norm - we got there in the end
