mk4ste 43 Posted July 9, 2017 The 2.0 pinto in my capri is using a lot of water, it is not leaking out anywhere and the car has not lost any power at all. There is no water in the oil or oil in the water. But the water disappears about a litre every 40 miles. :headscratch: Quote Share this post Link to post Share on other sites
smudger 2 Posted July 9, 2017 Water pump, head gasket, or cracked head. Water doesn't always find it's way into the oil. Sometimes it's sucked into the combustion chamber and comes out of the exhaust as water vapour. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
mk4ste 43 Posted July 9, 2017 forgot to mention i have changed the water pump. So i might as well just do the head gasket and see what happens then :smashcomp: Quote Share this post Link to post Share on other sites
dgo 80 Posted July 9, 2017 (edited) Is the rad cap OK? I had one that only seemed to leak only when I was up to speed. Was hard to find! Also wheel under the heater matrix in case that's leaking. Again really hard to see Edited July 9, 2017 by dgo Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 754 Posted July 10, 2017 Yes I'd try another cap had this one,also the water vapour too. See if you can get the cooling system pressure tested. If you were close could do it for you. Quote Share this post Link to post Share on other sites
buzzard 13 Posted July 10, 2017 Has it got a exspantion bolttle . If not it may be just dropping it on the road as it expands and because it's hot it's expanding more than usual .then when you take the cap of it looks low . Quote Share this post Link to post Share on other sites
the-ford-cortina.com 226 Posted July 10, 2017 Is it getting hot? if not I wouldn't change the head gasket on the off chance. Quote Share this post Link to post Share on other sites
RT 1006 137 Posted July 10, 2017 It's Brussels, first it's our freedom now they're now coming over and nicking the water out of your car Ste, down with the EU :gun: Quote Share this post Link to post Share on other sites
the-ford-cortina.com 226 Posted July 10, 2017 It's Brussels, first it's our freedom now they're now coming over and nicking the water out of your car Ste, down with the EU :gun: :rofl: :rofl: Quote Share this post Link to post Share on other sites
