markymarkthree
BREAKING MK3 2000E ESTATE
Sadly breaking this old chap.
Lots has gone but still a fair bit left.
Engine, gearbox, propshaft, carb, dizzy, starter and all ancillary's except alternator. £300
I had the engine and gearbox turning nicely over on the key, all sounded good but I couldn't quite squeeze a spark out of it.
Edited by markymarkthree
Are the front seats available Marky? Just need the plastic trim around the bases but will take complete seats if you don't want to split.
Not to sure at the moment Kev, someone is interested in the seats I am awaiting a reply.
I think the trims are sold, however we (The MK3 CLUB) are looking into getting some made.
what are the rear side window rubber seals like?
Rear seals are badly perished and will probably far apart when I remove the glass, hopefully later today.
Mark, radio and washer tube scuttle support clips please.
god knows where my clips went
support beackets for air filter box to inlet manifould
accelerator cable support bracket if ealy type?
Pete
Is the heater box the fibreglass type? If so and it's in good nick I'm interested as I might need a spare depending upon how I get on stripping and refurbishing mine :)
Couple of other things, radiator and windscreen.
Kev
Think I've a fibreglass box buthas bit of damage on edge.
Pete: radio and clips £30, clips I shall pop in the post today radio I shall take to NEC if that's ok. Support bracket may be sold. Accelerator cable support bracket I want to keep with the engine and box and sell as one lump.
Mahem Pete : arch trims sold.
Kev: heater box disintegrated, all glass sold, radiator is out and hopefully ok I shall have to double check £25. Are you going to the NEC in November?
Joe: rear axle I shall be keeping.
Is the prop shaft available?
Yes, but with the
Thanks I only need the prop if you decide to split it from the sale of engine and gearbox let me know, that is a good price for all of that by the way.
Think I've a fibreglass box but has bit of damage on edge.
Thank's Craig I'll bear that in mind and see how I get on with mine
PM'd you Marky
Hi, is the front axle/steering and brakes etc available please ?
Louie
