gheebhow 4 Posted October 22, 2017 Hi all, I'm after a new master cylinder. The fitted one is a Girling (on the body: 74660294 0 Q180) with a red tag (66197 01/38 62 12KP). Anyone got one they're willing to part with? Cheers, Neil Quote Share this post Link to post Share on other sites
nmonkey220 23 Posted October 31, 2017 Have you considered an early landrover defender one they fit straight up and only require new unions. https://www.buysellcortina.co.uk/forums/index.php?/topic/73271-which-landrover-master-cylinder/https://www.buysellcortina.co.uk/forums/index.php?/topic/73271-which-landrover-master-cylinder/ Quote Share this post Link to post Share on other sites
markymarkthree 170 Posted October 31, 2017 Not that I am up to speed with modern cars like the MK5, but doesn't it have 3 pipes coming off the M/C as opposed to 2 on the MK3. In which case the L/R one will be no good. :juggle: Quote Share this post Link to post Share on other sites
nmonkey220 23 Posted October 31, 2017 you are correct wasn't thinking Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 669 Posted October 31, 2017 To use the 3 outlet one on a 2 pipe one,either put a bleed nipple in the bottom front outlet or do away with the T piece on the bulkhead & run the pipes straight to the front calipers from the the master cylinder. Quote Share this post Link to post Share on other sites
duffus01 0 Posted November 1, 2017 Hi all, I'm after a new master cylinder. The fitted one is a Girling (on the body: 74660294 0 Q180) with a red tag (66197 01/38 62 12KP). Anyone got one they're willing to part with? Cheers, Neil I just bought a new one from my local motor factors Quote Share this post Link to post Share on other sites
