Beowulf 87 Posted July 7, 2019 3 hours ago, d.p.n.s said: that might acually be one of the last parts i buy mate... I guessed that might be the case but following your thread with great interest 👍 1 Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 524 Posted July 7, 2019 That looks great can't quite figure where you welded bracket any better pics? Is the Suzuki in still fitted ( Inside car)? What have you used to go through to the Cortina uj as it's triangular & the Suzuki looks round? Quote Share this post Link to post Share on other sites
d.p.n.s 93 Posted July 8, 2019 2 hours ago, sheffieldcortinacentre said: That looks great can't quite figure where you welded bracket any better pics? Is the Suzuki in still fitted ( Inside car)? What have you used to go through to the Cortina uj as it's triangular & the Suzuki looks round? its all bolted in the cortina at the moment. sorry no better povs of the mount..i just mounted the cortina 1 in place and cut it till i could fit the suzuki 1 in and tacked it up.Pulled it back out and welded it as well as some bracing. i need to gwt a small section of shaft made....splined one end and rectangle the other....( still might buy some bits and make it all new from rack to coloum.) Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 524 Posted July 8, 2019 No prob now I'm clearer on what you did.looks a good job well thought out. 1 Quote Share this post Link to post Share on other sites
d.p.n.s 93 Posted July 8, 2019 32 minutes ago, sheffieldcortinacentre said: No prob now I'm clearer on what you did.looks a good job well thought out. i did it years ago with an escort van i built....but much harder getting it in the cortina... its somthing i will need as the old 4.1cast iron block is bloody heavy lol.. and didn't want to go power steeting rack and pump. Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 524 Posted July 9, 2019 There harder find now days so this will be a good alternative as it's never been a common thing where cortinas are concerned over here. Most esp conversion are on things that never had any Pas option to start with. 1 Quote Share this post Link to post Share on other sites
Lobby 99 Posted July 9, 2019 Just catching up with this thread, ingenious PAS set up! 1 Quote Share this post Link to post Share on other sites
d.p.n.s 93 Posted July 9, 2019 1 hour ago, Lobby said: Just catching up with this thread, ingenious PAS set up! cheers mate Quote Share this post Link to post Share on other sites
d.p.n.s 93 Posted July 13, 2019 fuel tank boot floor time.... i wanted to change the tank as the cortina one was stuffed so i looked around and decide on a 68 mustang brand new was $210 landed..and that meant losing the boot floor wheel well (didn't like that anyway) it was in good condition and got blasted with the shell so i advertised it and donated it to another build. so i started with a massive hole in the boot and decided to use some box section and the main brace after i welded it up i measured again and found out i stuffed it up hahaha.....measure 6 million times kids and cut once..so after i cut 100mm out of it i welded it back up again so after getting it right i tried it in the hole...apart from having to cut a 45* off the back corners for the chassis rail it fitted. and i welded as much of it in as i could. then it was time to make new floor parts....starting with the rear part. then the passenger side then the drivers side. then made the 2 caps for the back corners from where i had to trim it for the chassis rails. then a quick clean up and throw the tank in to see if it fits. 2 Quote Share this post Link to post Share on other sites
nmonkey220 23 Posted July 13, 2019 That looks like it has been there all the time mate cracking job 1 Quote Share this post Link to post Share on other sites
Steve Walton 128 Posted July 13, 2019 I do appreciate a great project. Fantastic fabrication work going on there. Cheers Steve 1 Quote Share this post Link to post Share on other sites
Beowulf 87 Posted July 13, 2019 Lovely work there! 1 Quote Share this post Link to post Share on other sites
d.p.n.s 93 Posted July 13, 2019 4 hours ago, nmonkey220 said: That looks like it has been there all the time mate cracking job yeah im really happy with the way ut turned out. Quote Share this post Link to post Share on other sites
d.p.n.s 93 Posted July 13, 2019 3 hours ago, Steve Walton said: I do appreciate a great project. Fantastic fabrication work going on there. Cheers Steve ive build a few project in the past...but this is the first time ive gone this far....and accually bought things like a bead roller. and a folder..(use to fold everything over my bench...so its still a learning curve... but loving it. Quote Share this post Link to post Share on other sites
d.p.n.s 93 Posted July 13, 2019 26 minutes ago, Beowulf said: Lovely work there! cheers mate Quote Share this post Link to post Share on other sites
