chinkamon 14 Posted December 17, 2017 Hi all Lookin at fitting twin carbs on my mk1 however it's rod controlled on the existing carb, the twin carbs are cable set up, what's the easiest way to convert the old to new set up? Any thoughts? Thanks in advance Quote Share this post Link to post Share on other sites
Pete-H 69 Posted December 17, 2017 (edited) What carbs as webcon do or did a rod conversion for twin 40 DCOE Webber carbs to use the standard Mk1 system. Edited December 17, 2017 by Pete-H Quote Share this post Link to post Share on other sites
chinkamon 14 Posted December 17, 2017 Twin sus thought I'd be a bit different ! Quote Share this post Link to post Share on other sites
Pete-H 69 Posted December 17, 2017 Could still do it with rods just may take a bit of working out, much better than cables no delay in response. Quote Share this post Link to post Share on other sites
chinkamon 14 Posted December 17, 2017 Just a bit of fabrication then yea? 1 Quote Share this post Link to post Share on other sites
nosher 1 Posted January 5, 2018 I welded a small rod on to the existing accelerator pedal and then used a sytec throttle cable block...simples.. Quote Share this post Link to post Share on other sites
chinkamon 14 Posted January 6, 2018 Cheers nosher Seems to be the common answer from most, so time to squeeze myself under the dash an take a look at what I can do, (as I can't weld! ) So a bit of engineering will be needed 😁 Quote Share this post Link to post Share on other sites
