Donncha
Electronic start
Hi Folks,
I am looking to sort for once and for all the starting/running issue with Mk mk3 cortinas, I have the same problem/symptoms with both cars.
They do not start very well or if started don't run well at all ! with the current electronic system that replaced the points.
I am told that an electronic system from a sierra would be a good reliable option which I am open to fitting.
I am looking to know if anyone have this system already installed and if so what it entail to install such a system.
Is it a straight swap for the current timing system, and is there a wiring module required for this system also.
I am hoping it is straight forward uncomplicated installation that I could tackle myself.
Thanks for any help on this.
Denis.
Yes its about 5 wires (theres a how to on here somewhere) +swap the ballast wire for a normal piece & swap coil for 12v non ballast version & mount module on inner wing.
Ok thanks Craig,
If anyone comes across the link please do pass it on.
Denis.
