brian grech 109 Posted May 11, 2018 Looking for fuel tank hook bolts in very good condition.Must be able to post to UK or Maltese address.Thanks Quote Share this post Link to post Share on other sites
nogE 69 Posted May 12, 2018 Brian..iv seen these kits on ebay.. 351990621050 item number Quote Share this post Link to post Share on other sites
brian grech 109 Posted May 12, 2018 Brian..iv seen these kits on ebay.. 351990621050 item number Thanks but have the straps powder coated already so i only need the bolts.Thanks again Quote Share this post Link to post Share on other sites
Danish 288 Posted May 12, 2018 Looking for fuel tank hook bolts in very good condition.Must be able to post to UK or Maltese address.Thanks Do you want genuine, or will aftermarket like these do? https://www.ebay.co.uk/itm/M6-M8-J-HOOK-BOLTS-SQUARE-NUTS-ROOFING-GUTTERING-FENCING-FIXING-ZINC-PLATED/182609018670?hash=item2a84587f2e:m:mFeywfEzXKSpXP2ip1-YIxw Quote Share this post Link to post Share on other sites
brian grech 109 Posted May 12, 2018 Do you want genuine, or will aftermarket like these do? https://www.ebay.co.uk/itm/M6-M8-J-HOOK-BOLTS-SQUARE-NUTS-ROOFING-GUTTERING-FENCING-FIXING-ZINC-PLATED/182609018670?hash=item2a84587f2e:m:mFeywfEzXKSpXP2ip1-YIxw HI Danish these will do however i have no idea where mine are so unsure what size and length to look for. Thanks Quote Share this post Link to post Share on other sites
Danish 288 Posted May 12, 2018 (edited) I have a pair I could measure - but they're in the loft and I can't get up right now. However, Old Part Store list a nut suitable for tank bolts, OHC inlet manifold and ARB drop link. So they must be M8. Measuring this photo: http://www.oldpartstore.net/shop/798-fuel-tank-mounting-bolt.html suggests around 110/120mm is what you need. However, I wouldn't order on the basis of my ramblings, I'm sure someone will be along soon who can measure on for you! Edited May 12, 2018 by Danish Quote Share this post Link to post Share on other sites
brian grech 109 Posted May 12, 2018 I have a pair I could measure - but they're in the loft and I can't get up right now. However, Old Part Store list a nut suitable for tank bolts, OHC inlet manifold and ARB drop link. So they must be M8. Measuring this photo:http://www.oldpartstore.net/shop/798-fuel-tank-mounting-bolt.html suggests around 110/120mm is what you need. However, I wouldn't order on the basis of my ramblings, I'm sure someone will be along soon who can measure on for you! Thanks Danish much appreciated. Quote Share this post Link to post Share on other sites
Steve Walton 75 Posted May 12, 2018 Hi Brian, If you ask these people they might sell you a set of Tank Strap Bolts on there own. I have used them for all of the panels for my MK5 and found them very helpful. Cheers Steve https://www.ebay.co.uk/itm/Ford-cortina-Mk3-Mk4-Mk5-fuel-tank-strap-set-fitting-kit-New-Inc-Bolts/351990621050?fits=Model%3ACortina&hash=item51f446a37a:g:KncAAOSwtfhYsAZQ Quote Share this post Link to post Share on other sites
brian grech 109 Posted May 12, 2018 Hi Brian, If you ask these people they might sell you a set of Tank Strap Bolts on there own. I have used them for all of the panels for my MK5 and found them very helpful. Cheers Steve https://www.ebay.co.uk/itm/Ford-cortina-Mk3-Mk4-Mk5-fuel-tank-strap-set-fitting-kit-New-Inc-Bolts/351990621050?fits=Model%3ACortina&hash=item51f446a37a:g:KncAAOSwtfhYsAZQ Thanks :cheers: Quote Share this post Link to post Share on other sites
consul315 93 Posted May 18, 2018 perhaps these? though they look a bit strange they should do the job and as stated he posts to Malta as well: https://www.ebay.de/itm/Satz-Tankhalteschrauben-Edelstahl-V2A-Ford-Capri-II-III-Granada-Taunus/292568052780?hash=item441e6a342c:g:Ud4AAOSw~gRV2eI3&clk_rvr_id=1534556293202&rmvSB=true Quote Share this post Link to post Share on other sites
brian grech 109 Posted May 18, 2018 perhaps these? though they look a bit strange they should do the job and as stated he posts to Malta as well: https://www.ebay.de/itm/Satz-Tankhalteschrauben-Edelstahl-V2A-Ford-Capri-II-III-Granada-Taunus/292568052780?hash=item441e6a342c:g:Ud4AAOSw~gRV2eI3&clk_rvr_id=1534556293202&rmvSB=true Thanks yes they do look strange,Thanks again Quote Share this post Link to post Share on other sites
Mk3 Mahem 3 Posted May 19, 2018 I managed to fit these stainless Capri one's, sorry cant remember if i had to open up hole a bit or if they went straight in. https://www.tickover.co.uk/shop/contents/en-uk/d334.html Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 282 Posted May 19, 2018 There basically M8 bolts so could easily make some, I've probably some used ones if you have no luck. Quote Share this post Link to post Share on other sites
RichardJ 51 Posted May 19, 2018 <blockquote class='ipsBlockquote'data-author="Mk3 Mahem" data-cid="673418" data-time="1526748162"><p> I managed to fit these stainless Capri one's, sorry cant remember if i had to open up hole a bit or if they went straight in. <br /> <br /> <br /> <a href='https://www.tickover.co.uk/shop/contents/en-uk/d334.html'>https://www.tickover.co.uk/shop/contents/en-uk/d334.html</a></p></blockquote> I used these ones, too. Straight fit, no mods and are completely rust proof. I also managed to get stainless straps from ebay. Quote Share this post Link to post Share on other sites
brian grech 109 Posted May 20, 2018 I managed to fit these stainless Capri one's, sorry cant remember if i had to open up hole a bit or if they went straight in. https://www.tickover.co.uk/shop/contents/en-uk/d334.html There basically M8 bolts so could easily make some, I've probably some used ones if you have no luck. <blockquote class='ipsBlockquote'data-author="Mk3 Mahem" data-cid="673418" data-time="1526748162"><p>I managed to fit these stainless Capri one's, sorry cant remember if i had to open up hole a bit or if they went straight in. <br /> <br /> <br /> <a href='https://www.tickover.co.uk/shop/contents/en-uk/d334.html'>https://www.tickover.co.uk/shop/contents/en-uk/d334.html</a></p></blockquote> I used these ones, too. Straight fit, no mods and are completely rust proof. I also managed to get stainless straps from ebay. Thanks a lot guys i think i will go for the stainless steel ones. Cheers Quote Share this post Link to post Share on other sites
