Tony - Barking
Hazard light & heated rear screen connectors
Has anyone got the wires with plug that fit to the square hazard light and heated rear screen switches from the face lift MKIII Cortina? I think these are the same switches that are also on the MKIV & MKV Cortinas.
I need the connecting plugs with as much cable as possible.
Have you got??
Thanks,
Tony
I think ive got the hazards part will che k mon.
Sorry was an auto inhibitor relay/loom.
Check out some older Transits in a scrappy, if you can find any (or ask on a Transit forum) the triangle is the wrong way around as the switch sits left to right rather than up and down in the dash.
The hazards are a seperate add in loom on low spec m/n reg facelifts but higher spec & p reg onwards it's part of loom .
Think hrw is always part of loom.
