stavgtti
Mk2 door hinges
Im in need of both the O/S and N/S top door hinge for 2 door mk2. Located around the Surrey area so could pick up if local.
From what I can tell the top and bottom hinges are different (top is larger) and are unique to each side. So an O/S rear 4 door top hinge should fit an O/S 2 door top, could anyone confirm if this is right?
Thanks in advance.
no mate - sorry but the top fronts are only top fronts . backs are very different at the top - bottom ones will fit front or back doors .
