wolfrace
Desmo classic roof rack.
Hiya, i have a classic Desmo classic roof rack for sale (so prob mk3 era) in alloy. Most are steel and heavy but this one is light but strong, the legs that hold it to the gutter are steel though. The other advantage is if you want to go mad with some autosol you could probably get a mirror like chrone finish to it. As it stands its quite shiny, there are a few slight marks but it looks good.
All fixings are present and even the plastic clips & also the brackets that mount to the roof rails. Which are fully adjustible. Practical & looks pretty cool, you can bring bigger bits back from shows on the roof if you have a saloon.
It measures: legs allow around 18cm clearance in height from gutter to roof, load area is W67cm L111cm H14cm.
£75
