johnny boy
Johnnys 1965 Mk1 Cortina 2 door build
Posted (edited)
I had a bit of a set back over the Christmas period. I had a rear wheel bearing collapse. It made no noise leading up to the incident. I managed to limp home at about 10mph.
Both sides were ok when I built the axle up last year.
Both replaced now.
Edited by johnny boy
Thats a bugger, looks like it was a wobbler. Did you press off or grind ?
Tony
I pressed them off at work, then when I was at home over Christmas, I used a long piece of pipe to whack them home.
Also took the opertunity to change the diff oil, as the ATB has a few miles on it, and any running in swarf drained out.
I fitted the rear axle wedges today, to get a better diff nose angle .
Lowering tips the diff up at a higher angle.
With only rear axle weight on it's about 5  Deg, with full vehicle weight , I'm guessing about 3 Deg.
1 hour ago, tonyg64 said:
Nice, whats the gearbox angle?
Not sure, I had to be guided by the engine clearance to the front cross member, bulkhead , get the engine as low as possible, and have clearance for the gearbox.
I'm guessing it's about 5 degrees off horizontal, tipping back.
So you have (roughly) 5 down on the box and 3 up on the diff? if so that should be ok I reckon, was there any driveline vibration before (on lift off throttle maybe?)
No vibration, all ok, just wanted to get the u/js running at a shallower angle.
Probably more like 3 deg on the diff with the full weight on.
The gearbox sits up as high as it can go to the strengthening cross member under the car, as I knew I would be running it lowered, so the prop still ran at an angle.
Yes sounds like you got it nice then, fairly parallel it seems. :)
I made a start on some of the body work that i wanted to address this afternoon.
All the lower panels have a thick dull sounding coat of stone chip, that's always a worry , whats underneath.
So I scuffed off the rear panel , the 2 lower quarters, and the wheel arches.
Surprised it was very good. Sills and front panel next.
Always a relief to see steel under there :)
Just pleased...................
The sill were full of filler too, but fillered up because they were dented, Finnish stoney roads I guess.
