johnny boy
Johnnys 1965 Mk1 Cortina 2 door build
I used guage wizard on my efi dolomite and really like it, hence my asking. Ill look at the CBS stuff too
I will pick your brains, if I need to use one 😁
Rally design is another place I've used
Yeah no problem, the instructions are pretty good and the guy is on the end on the phone too. Hes the guy that does the rev counter conversions (spiyda?)
Ok, I used one of his kits on my rev counter
He does some clever stuff, but people only know him for the rev counters lol
Well I've made a start on putting it back together after the bare metal repaint.
Easy stuff first, although it was a bit of a fiddle getting the side light/ indicator lamps to fit inside the apature in the grill.🙄
Looks well, Nice to see it all done now :)
Fuel tank, and battery in today, cleaning up or painting as I go 😁
Dont forget to make sure the tank is grounded for the sender :thumbsup:
Tony
Tony
Yes Tony,  I had a bit of bother with the MK2 gauge not working, it turned out to be the sender hold in ring not contacting the gauge to tank, due to corrosion. I tapped it round a bit more , and it worked.
With the MK1 tank, I used bolts with nice sharp edged shake proof washers, to cut though the paint and underseal, on both sides, that worked too.
I put in a return pipe in the fuel tank when I refurbed it, so later on when I turbo it, I'll need to ditch the Weber's, and go to fuel injection, which needs the tank return.
Forward thinking 😁
I do forward thinking sometimes then forget it lol. What you doing about swirl pot/baffle for FI ?
I don't know yet, I'll cover that when I get around to it, or not 😁
Coming along nicely. Keep the pics coming Johnny.
When I did my Dolomite to efi I had intank pump but no swirl pot. Worked great til i was 1/4 tank and pulled some g's on a roundabout, instant fuel cut lol. Modded another tank to take the whole plastic pump assy from late model MX5. Plastic but uses a steel ring to push it down against the springy swirl pot. Screw on ones are more work to fit :biggrin:
Tony
