chinkamon 14 Posted September 25, 2018 Hi all So I'm looking to put some lotus style stripes on my mk1 Cortina but white, I wandered does anywhere sell them ready made? I bought white vinyl to make them but failed miserably as the lines aren't actually straight but curved slightly an my shakey hands aren't up to it. A local shop could make some but it'd cost a fortune due to the length of vinyl So I was just going to get some white spray but thought I'd ask here first Share this post Link to post Share on other sites
littlenewt2067 33 Posted September 25, 2018 I don't think anyone makes them ready made, but i think someone did have or made masking for them but prob best to mask up and go for it Share this post Link to post Share on other sites
chinkamon 14 Posted September 25, 2018 Yea I think you're right Share this post Link to post Share on other sites
GhiaMk4/5 207 Posted September 25, 2018 The Mk1 owners had them at one time, but if you get the best 3M masking pinstripe in 1/4 wide, you can do it yourself, but as you know the car and the lines are not 100% straight, so it does take a bit of effort to get it "just right", the only advice l can give you is apply the tape somewhere dry and reasonably warm, do not spray the paint on too thick as you will have problems when you remove the masking tape, and you will not get a sharp clean line, it will also possibly lift as you remove the tape, also remove the tape when the paint is just flashed off, to hopefully give you a nice sharp clean line. Are you going to clear coat over the paint, is the paint you are painting over sound, l would mask off, sand area with 600, panel wipe, tack rag, then Barcoat the area, then paint the white, sounds like a lot of fuss for a stripe, but the preparation is key, and l don't know what I'm doing, and still have paint problems, despite using the same process everyone. Even had fry ups through the Barcoat, which is meant to stabilise every kind of finish on a car. As above you could just go for it and throw caution to the wind, it has a fair chance of coming out perfect, l always find the bits that don't matter, come out perfect and the bits you want nice turn out crap. Just done a front bumper and forgot to do the headlight washer jet covers, 6 attempts later, 5 fry ups and they were painted!!!! Share this post Link to post Share on other sites
chinkamon 14 Posted September 25, 2018 Thanks for that ghia I had another short attempt with the vinyl, as the edges are a bit wobbly I've struck on an idea to hide/neaten the edges, if it works ill post a pic, if it doesn't then I won't say thing more about it😂😂 Share this post Link to post Share on other sites
Lotuscops 80 Posted September 25, 2018 If you do want to do it I have a guide showing the right dimensions etc. I too have white ones on mine.... :icecream: Share this post Link to post Share on other sites
chinkamon 14 Posted September 26, 2018 Well I've done passenger front wing both doors going to do drivers side when I can then tackle the rear so depending on how it turns out I may be in touch thanks! Share this post Link to post Share on other sites
littlenewt2067 33 Posted September 26, 2018 If you do want to do it I have a guide showing the right dimensions etc. I too have white ones on mine.... :icecream: And no masking lines showing!! :jester: :bleh: 1 Share this post Link to post Share on other sites
Lotuscops 80 Posted September 26, 2018 And no masking lines showing!! :jester: :bleh: Yes Jim Colin matched that paint perfectly too.... Share this post Link to post Share on other sites
chinkamon 14 Posted October 17, 2018 Well I was going to upload pictures to show you but I can't upload them! So you'll just have to imagine it 😂 1 Share this post Link to post Share on other sites
