nogE 91 Posted October 5, 2018 Looking for a couple..good used will be fine..anyone help.. Quote Share this post Link to post Share on other sites
Lotuscops 73 Posted October 5, 2018 Which model? Quote Share this post Link to post Share on other sites
markymarkthree 160 Posted October 5, 2018 New here. :) http://www.oldpartstore.net/shop/1954-courtesy-lamp-switch.html Quote Share this post Link to post Share on other sites
markymarkthree 160 Posted October 5, 2018 Cheaper here. https://www.ebay.co.uk/itm/New-Mk1-Mk2-Escort-Interior-Light-Switches/192340473848?hash=item2cc862b7f8:g:2ugAAOSwry1Z62o~ Quote Share this post Link to post Share on other sites
nogE 91 Posted October 5, 2018 Sorry...rule..what mk...I forget sometimes im on buysell..and not mk3 club site..thanks Mark... Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 529 Posted October 5, 2018 There not cortina though, I've good used £15 a pair Inc p&p Quote Share this post Link to post Share on other sites
nogE 91 Posted October 7, 2018 There not???... Craig.. do u use whattsapp..maybe get pics over..I know sort of what yr saying as I thought mk3 ones had white plastic tube like part .. Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 529 Posted October 7, 2018 (edited) Nope but hopefully will be here. If you want new ones the jaguar xj40 uses the same ones for the bonnet light. Edited October 7, 2018 by sheffieldcortinacentre Quote Share this post Link to post Share on other sites
markymarkthree 160 Posted October 7, 2018 (edited) Those little black button ones are on both my cars with the ones on the estate looking like the originals and there is a strange horseshoe shaped connector on the end of the brown wires. https://www.ebay.co.uk/itm/New-Mk1-Mk2-Escort-Interior-Light-Switches/192340473848?hash=item2cc862b7f8:g:2ugAAOSwry1Z62o~ Edited October 8, 2018 by markymarkthree Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 529 Posted October 8, 2018 Those are fitted to facelift ones dunno what the horse shoe thing is? Quote Share this post Link to post Share on other sites
martog 128 Posted October 9, 2018 Those are fitted to facelift ones dunno what the horse shoe thing is? The end of the wire. Think of a ring terminal with a bit cut out and it's horse shoe shaped. Nowadays these terminals are U shaped. Nor can you get the little double ended spade terminal for coils etc. Would make life easier for converting cars to electronic ignition without cutting the plugs off original wires. Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 529 Posted October 9, 2018 Do you meen the crimp on spade terminal with male & female end? If So got some of those, or the double male that bolt to coil terminal? As there easy enough to make from a strip of metal plate. Quote Share this post Link to post Share on other sites
Kenworth W900 38 Posted October 9, 2018 Are you talking about 'piggy back' crimp terminals? Quote Share this post Link to post Share on other sites
markymarkthree 160 Posted October 10, 2018 This is the horseshoe shaped conector fitted to both my PFL cars also fitted to this PFL loom. Check the size of the hole in the A post Gary, as i think the white switch requires a bigger hole. Quote Share this post Link to post Share on other sites
nogE 91 Posted October 10, 2018 Yep..that's the type i hv on cobron mark..Craig.. yrs are facelift yeah?..they should hv rubber boot over there tops ..I hv them on ojo..tho preface..dam sure I hv two of them in boxes..I'll.hv to check again.. thank u for looking..and info..if I need them ill text u 👍👍 Quote Share this post Link to post Share on other sites
