joemayhook 7 Posted December 27, 2018 Hi to check the connections to my fuse box do I have to o in via under the footwell looking up, or if I unscrew the two retaining screws on the fuse box should it just lift out? Ive been having nightmares with no dipped beam, only side lights. I have just run a lead from + on the battery to number 4 fuse and the lights are working, so I know all is well between the fuse and the bulbs, so I'm just working my way back from the fuse box to the battery. any advise would be very well received believe me. Cheers all Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted December 27, 2018 Check through the light circuit methodically from battery to bulb until you loose power. Quote Share this post Link to post Share on other sites
joemayhook 7 Posted December 27, 2018 cheers, fingers crossed Quote Share this post Link to post Share on other sites
MK5 V8 1 Posted February 11, 2019 check the connections that come out the side of the fuse box, i had a similar problem, no dip but main, then no main but dip and it was those connections Quote Share this post Link to post Share on other sites
Graeme Fish 0 Posted April 23, 2019 I had similar problems when putting my main lights to full beam and the headlights all went out .. check the connection from the driver side footwell and push the connections to the back of the fuse box in firm, it sorted my problem in seconds. Quote Share this post Link to post Share on other sites
