Smithaam
change hubs/shafts on cortina P100 rear axle
I'm looking at my rear axle on my pick up and thinking of changing the hubs on there for 4 std.
I do have an Atlas off a mk3 cortina but I'm guessing the shafts are not interchangeable?? just looking for some info and options.
No won't fit as it's actually a Borg Warner axle.
Either use a MK2/3 Capri or MK3/4/5 axle both need new spring perches welding on ,prop & handbrake cable will still fit.
Cheers for that! will probably just keep as is for now. the wheels on the back of my pickup dont fit properly so was looking to open up more wheel choices!
Cortina P100 is same as rover P4/5/6/SD1 & Jeep 2000 onwards.
5x41/2 inch
