cortinasuper1500 8 Posted August 1, 2019 Repaired the chassis rail at the engine mount on drivers side, nearside to be tackled next... The bonnet is for sale, the frame is well past being repairable, the skin is still useable, if anyone is interested contact me. Quote Share this post Link to post Share on other sites
cortinasuper1500 8 Posted August 1, 2019 Took the Pinto engine for a he alth check and power run on the dyno, If its healthy it will be for sale as replacing it with a cross flow. Quote Share this post Link to post Share on other sites
tinman 11 Posted August 3, 2019 😆im still amazed how you managed to get those in😆...bet your great at packing a suitcase🤣 Quote Share this post Link to post Share on other sites
cortinasuper1500 8 Posted August 3, 2019 (edited) Gayvans are awesome, you can get 20 bags of compost, or 101 Redland Renown roof tiles in when spread around the whole car Edited August 3, 2019 by cortinasuper1500 spelling and grammer Quote Share this post Link to post Share on other sites
cortinasuper1500 8 Posted August 3, 2019 (edited) Well it has been run and all is good now, the idle was big issue so operator removed and cleaned all the jets and it produced 110 hp and 130 lbft torque. No additional tuning was done with jetting or timing, it had to come off as more engines queued up and was run as massive favor, top bloke... Edited August 3, 2019 by cortinasuper1500 Quote Share this post Link to post Share on other sites
nascar66 74 Posted August 4, 2019 Good thread this. That mk2 will look great when you've finished. Quote Share this post Link to post Share on other sites
tinman 11 Posted August 4, 2019 looking forward to seeing this one on the road myself !! nice thread😉 Quote Share this post Link to post Share on other sites
cortinasuper1500 8 Posted August 6, 2019 (edited) Having spoken with a knowledgeable engine builder, In his opion the cam timing is not correct as the graph is showing that the power rolled off too early... Where is a Ford H33 cam from? -- Cortina,Capri,Transit,Escort Edited August 6, 2019 by cortinasuper1500 Quote Share this post Link to post Share on other sites
cortinasuper1500 8 Posted August 6, 2019 (edited) Wheel well done, One more task ticked off 🙂 Edited August 6, 2019 by cortinasuper1500 Rearranged images Quote Share this post Link to post Share on other sites
cortinasuper1500 8 Posted August 6, 2019 (edited) Before and after from the previous chassis rail repair, The oppsite rail is in much better condition much less effort required Edited August 6, 2019 by cortinasuper1500 Rearranged images 1 Quote Share this post Link to post Share on other sites
cortinasuper1500 8 Posted August 7, 2019 Cleaning up for the rear valance exposed a gap between the boot floor and the lower rear panel. When applying pressure to the chassis rail it can be lifted 8 to 10mm.... Quote Share this post Link to post Share on other sites
austwombat 4 Posted August 8, 2019 on mine the boot floor extends to the back of the lip on rear panel making a 3 layer sandwich between rear panel and valence from wheel well to tool kit well. Someone on here should know if that is normal or an "aftermarket accessory" Quote Share this post Link to post Share on other sites
Steve Walton 128 Posted August 8, 2019 8 minutes ago, austwombat said: on mine the boot floor extends to the back of the lip on rear panel making a 3 layer sandwich between rear panel and valence from wheel well to tool kit well. Someone on here should know if that is normal or an "aftermarket accessory" Hi, I can confirm that the 3 layer sandwich is correct. Rear Valance, Rear Panel and boot floor in the middle. Cheers Steve Quote Share this post Link to post Share on other sites
