SirRobin
Oil pick up pipe for alloy trough sump?
Hello
I managed recently to get an alloy trough sump, total depth is about 140mm with the hole in the internal baffle in the centre.
The engine is a 2731 1500 Pre Crossflow so it has the Crossflow hole for the oil pick up.
Anyone any ideas on what I can get for the oil pick up as the current one goes straight down i.e front bowl type.
Thanks
Terry
If this sump is intended to fit a Crossflow engine, I think you will have a problem if your engine has a rope type rear oil seal. If your engine is originally from a mk2 Cortina and has a Crossflow type seal, then please disregard my ramblings!
I would think that a pickup pipe from a rear bowl Crossflow engine could be made to fit.
Thanks, yes its a 6bolt pre crossflow engine from an earlty Mk 2 Cortina
A 2731 casting
I think thats the pipe that Burton sells?
Thanks
Terry
What's an alloy trough sump? A photo might help me coz I'm thinking you might've got a dry sump sump for some reason?
Edited by Barnstormer
Ah OK, a Caterham sump - the pickup pipe isn't like anything you'll find easily. It has a rectangular pick-up face and gauze - see picture.
I have seen custom made ones using a modified 1300 or 1600 mk1 / mk2 escort pickup pipe - you use the mk1 / mk2 escort gauze filter so it's not like the one below but should do the job.
Sounds like you need to make a custom one, or keep your fingers crossed you find one!
Thanks for the info, its funny it looks as if it goes straight down with a kink?
I may be able to bend my standard 2731 oil pick up?
Edited by SirRobin
Yeah they are kinked, and the other bit on it is for later engines - just clamps it to the block at the side of number 3 main bearing. You could drill and tap your block if you find one of those Caterham pick-up pipes as 2731 blocks don't have the thread.
You could possibly bend yours. I would be worried about creasing the pipe though - perhaps fill it with sand(?) and/or heat up.
Thanks, will give it a go, sand, heat and a French 12mm pipe bender 🙂
cheers
Terry
Please sign in to comment
Sign In Now
