dmc 3 Posted March 2, 2019 As some of you may know i had my mk4 stolen a couple of weeks ago and i am trying to repair the damage, i need the steering lock just the lower part will do, the ignition barrel is not important as i have a new lock set, i also need the bit of loom and ignition cap which goes on the back of the switch and the steering column shrouds preferably in black although will consider anything Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 523 Posted March 2, 2019 No prob ,£15 for both bits upper & lower Inc p&p. Which plug has yours got I presume the flat grey one ? Quote Share this post Link to post Share on other sites
dmc 3 Posted March 3, 2019 im not sure if its flat but it definitely grey Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 523 Posted March 3, 2019 MK3/early MK4 are a flat rubber grey one,Some later MK4/5 are a square grey one then late Mk5/p100 are a black square,the wires & switch are same just the plug differs so can be swapped & resoldered if necessary. Might have one if you can let me know which it is? Quote Share this post Link to post Share on other sites
dmc 3 Posted March 4, 2019 it looked like a square plastic one from memory Quote Share this post Link to post Share on other sites
