Gheko 0 Posted July 10, 2019 ...My 71 Mk3 cortina needs her rearbushings done, complete set. What’s the best ones to use and where’s best place to purchase. Also seems to have different sizes available, any idea what size I need. I’d like to have them before I start to replace as I don’t want it off the road too long waiti... Quote Share this post Link to post Share on other sites
dgo 80 Posted July 10, 2019 You have a choice - either polybush or rubber. Best place for rubber is South Wales props Linky Personally I'd go for the HD ones (i.e. solid rather than void) if you're going rubber. Many opinions on Poly. Depends on your view of price vs customer service/quality. Amongst others you can go; - cheaper Floflex - expensive but usually regarded as top quality Superflex Bushes are the same Mk3/4/5 on the rear suspension top arms and the axle end bottom arms. The chassis end of the bottom arms are different sizes. You really need to measure those unless you absolutely know your axle is the original Also there are different opinions around full poly vs part. Personally I have Floflex on mine except the axle end top arms - because those have to move through a weird arc and need to be able to flex. Assume you know what you're doing to replace the bushes i.e. you have the tool/appropriate bolts/washers to remove and replace the bushes? Poly are different to fit, some you need to retain the outer metal shell from the originals so don't destroy those until you know Quote Share this post Link to post Share on other sites
Gheko 0 Posted July 10, 2019 Dgo thanks for that, very informative will probably go rubber so and measure up 👍🏻 Quote Share this post Link to post Share on other sites
dgo 80 Posted July 10, 2019 WHat you're looking for is the difference between EM1490 and EM1491 in the SWP list. They're quite significantly different once you look at the one on your car Quote Share this post Link to post Share on other sites
