peej
Mk3 F/L lower arm to chassis tie bars
Hi,
I’ve worked out why my car pulls to one side when braking (see picture).
Does anyone one have a pair of Mk3 Facelift tie bars?
 I don’t remember hitting a massive bump (I could have done with all the pot holes around here). Is it possible for this to have been caused the by tie bar’s connection to the chassis being too tight?
Cheers
Paul
MK4/5 are the same,don't forget there handed.
In terms of your "being too tight" question. That shouldn't be possible as long as you have the metal spacer/sleeve that's fitted inside the bush. The big washers press against the ends of that rather than being just a  tight fit on the bushes
