gheebhow 4 Posted August 8, 2019 Hi all, Could someone please remind me what gauge hose I need for replacing the short length of flexible hose into the fuel tank sender and at the engine end? I think the two pipes of the sender are slightly different widths? I couldn't find anywhere on here that said the gauge. Thanks. I'll be sure to get one that's E10 compatible. Quote Share this post Link to post Share on other sites
John Mack 337 Posted August 9, 2019 I "think" the feed is 8mm and return is 6mm (inside diameter), I can check properly this evening. Maybe someone can confirm ? Quote Share this post Link to post Share on other sites
gheebhow 4 Posted August 9, 2019 Thanks John - and do you know what diameter the pipes at the engine end are please? Quote Share this post Link to post Share on other sites
John Mack 337 Posted August 9, 2019 I've just replaced mine at engine end......I'm assuming they'll be the same at the tank?? Will go out and confirm sizes now. Quote Share this post Link to post Share on other sites
gheebhow 4 Posted August 11, 2019 Thanks John Quote Share this post Link to post Share on other sites
John Mack 337 Posted August 12, 2019 8mm feed to carb, return from carb is 6mm Quote Share this post Link to post Share on other sites
gheebhow 4 Posted August 12, 2019 Brilliant - thank you! Quote Share this post Link to post Share on other sites
Tigdlo 27 Posted August 12, 2019 Don’t forget those between the front subframe and chassis (in o/s wheel arch). Quote Share this post Link to post Share on other sites
dgo 80 Posted August 13, 2019 While you're doing this it's worthwhile making sure you fit "ethanol-proof" hose Quote Share this post Link to post Share on other sites
gheebhow 4 Posted August 13, 2019 Yes, definitely dgo - thanks. That's one of the reasons for replacing them, the other being that the fuel sender's leaking (again) and the hoses at that end looked a bit threadbare when I went underneath. Tigdlo - thanks, I hadn't clocked those short pieces, I'll do those too. Quote Share this post Link to post Share on other sites
