dobbo 0 Posted October 11, 2019 Trying to find a suitable Lower Radiator Hose for my MK3 from the TX1 Black Cab Radiator up to the Water Pump inlet on the engine. Viscous fan removed so distance from radiator before going up to the water pump is very short. If anyone has the same engine/rad set up, you may just be able to help. Many Thanks Quote Share this post Link to post Share on other sites
deltamal 37 Posted October 14, 2019 (edited) On 10/11/2019 at 5:35 PM, dobbo said: Trying to find a suitable Lower Radiator Hose for my MK3 from the TX1 Black Cab Radiator up to the Water Pump inlet on the engine. Viscous fan removed so distance from radiator before going up to the water pump is very short. If anyone has the same engine/rad set up, you may just be able to help. Many Thanks I used a Samco silacone hose on mine, just measured up the pipe sizes and chose the nearest shape they made, not sure which one it was now as it's a few years ago, I found that the taxi rad did not keep mine cool enough so I cut the slam pannel out a bit and fitted a big aluminuim one, the engine has been uprated a bit so that could be why. Edited October 14, 2019 by deltamal incorrect spelling 1 Quote Share this post Link to post Share on other sites
dobbo 0 Posted October 14, 2019 Thanks for your reply. From your photo yours looks something special. Love the rocker covers. I have also found the TX1 Rad doesn't really keep it cool enough. I'm always keeping my eye on the Temp gauge and switch on my manual overide fan whenever i get caught in traffic. Would love to see some more detailed photos of the your Radiator with Coolant Hoses and your Electric Fan set up on yours if you would be O.K with that. Would serious consider upgrading my Rad and Fan, just not sure what would fit and what would work. Thanks once again, speak soon. Regards Nick (Dobbo) Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 529 Posted October 14, 2019 I use a transit smiley rad with my ford V8 it just fits between chassis rails with the brackets etc trimmed of rad. I've trimmed slampanel similarly & the front inner panel too. I'll try get some pics tomorrow. Quote Share this post Link to post Share on other sites
dobbo 0 Posted October 15, 2019 Would be good to see a few more photos of your V8. Bet it sound fantastic. I'm afraid i only have the 2.9 V6 Cologne but have been wanting to upgrade the radiator for some time due to it heating up very quickly as soon as you hit traffic. Its just knowing what larger radiator would fit in the MK3 and then what hoses to use to couple the Rad to engine. I have got rid of the viscous fan and have an electric fan on the forward side of the radiator. Let me know what your thoughts are on this. Cheers Nick (dobbo) Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 529 Posted October 15, 2019 In the past I would use V6 Capri/Granada rads when fitting V6's but there expensive now days. These pictures of my 302 (5.0) ford V8 MK3 may be a bit dark ( not much room left with this in there) but I've had this combination for over 10 years. For more info pm me & I'll give you my number. Not great with computers. Quote Share this post Link to post Share on other sites
dobbo 0 Posted October 18, 2019 An engine i would just love in my MK3. Your photos still show an engine well worth talking about. Well done on your project. As for my 2.9 12 Valve Cologne i would like to fit a Bigger Radiator. I know i am limited to the Type/ Size of rad but if you could offer me any help from your experience on what type of Radiator to buy including the hoses which would be the correct shape to match up to the water pump and top of the engine your help would be much appreciated. You said you have you V6 Capri & Granada Radiators. What MK of Capri & Granada radiators did you use ? Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 529 Posted October 18, 2019 MK2/3 Capri for Essex or cologne with matching pipes. MK1 Granada for Essex & MK2 for cologne. If the taxi one isn't working Id opt for one of these but there expensive now days. Not many rads nowadays come with a cap. For most other conversion's I've used what ever seemed to fit. With. Twincams I use either 90'astra rad with modded twincam lower hose can't remember top one orI If i use aTX1 rad I use a Capri ohc top hose with I think twincam lower. When I did MX5 into escort I used RsS2000/MK2 transit ohc rad but can't remember what hoses.think top was ohc. I remember the Sierra rad used to over cool the efi pinto in my mates HC viva EST we swapped it for cortina/Capri ohc one. Quote Share this post Link to post Share on other sites
dobbo 0 Posted October 19, 2019 http://www.coolexperts.co.uk/product/ford-capri-2-8l-2-9l-cologne-engine-core-race-quality-radiator/ Thanks for your reply on what radiator would be suitable with my 2.9 12 Valve Cologne engine. I have sent a link above. Would this radiator be o.k ? Do you know if it would match up with the water inlet & outlets on the engine and would it fit in the engine bay ? Electric fan would be mounted on the front of radiator behind the grille. Again your help much appreciated. Just that i can't spend this sort of money unless i know it will fit. Sound like you have had experience fitting different radiator within the mk3. Regards Nick (dobbo) Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 529 Posted October 19, 2019 Let me check up. This is one of the reasons people use the taxi one it's a lot cheaper. I've been involved in maintaining, modding & restoring especially MK3/4/5/P100's since the mid 80's ,on budget so perfectly understand what you mean re getting things right. Quote Share this post Link to post Share on other sites
dobbo 0 Posted October 20, 2019 Really Appreciate your help. It's a lot of money as you know. Doesn't have to be this one but would like a new one. Been looking on Ebay and seen the odd secondhand Capri V6 Cologne Rads for £70 - £80 and probably not much good either. If you could let me know what you can find out that would be a great help. Regards Nick (dobbo) Quote Share this post Link to post Share on other sites
