Tony - Barking
6 Cylinder rev counter
Does anyone know if a Capri rev counter will fit in a 1975 Cortina MK3 FL?
If it will - do you have one??
Thanks,
Tony
One here...£50 delivered
Replied on R/R too.
Hi Cactus,
Are you sure it will fit my FL clocks which are the same as the MK4 & 5?
Happy to purchase if it does and is a 6 CYL
Thank you,
Tony
07754942035
No it's to big.
You need a mk4-5 one.
? The face must've been swapped as the Capri one is bigger than Cortina one so doesn't fit the cluster.
The bottom of face will have 4cyl or 6cyl on it respectively, this doesn't help though if they've been swapped.
You can either fit the full mk4-5 cluster or swap the gauge it's held in by 4 screws.
FFS....
SCC...THIS IS A COMPLETE MK5 CORTINA V6 CLOCK ASSY
Hope this is clear!!!!!
  • Haha 1
And there was me thinking I'd be able to offload a set of Capri V6 clocks I found a couple of weeks back while tidying up, lol.
Sorry, apparently they will not fit my dash cluster.
Thanks,
Tony
Well excuse me but Capri clocks were mentioned ,not seeing your retro rides post how are we too know your refering to a set of Cortina clocks your not supposed to bad mouth people on retro rides but you don't think people on here deserve the same ,pardon me for only having a lifetimes experience in fords  & was trying to clarify things so one party wouldn't be wasting the others time & money, you gobby c*nt I hope that's clear!!!!!
PERHAPS I SHOULD WRITE IT IN CAPITAL's TOO FOR THE HARD OF THINKING!!!!
  • Like 3
As proven on the sunroof question, your knowledge of Cortina's is second to none and anyone from the outside looking in, you are always trying to help people, so this is a little bit out of order and someone else needs to wind there neck in, AND IT'S NOT YOU.
  • Like 2
Thank you .
