Twinstacks
Bottom front Wishbone
Hi gents. New to this forum so if I have put this in the wrong place I apologise. I have a cortina mk 5 based kitcar and need some parts and thought this would be a good place to start.
firstly I need an o/s front wishbone as mine is damaged and I need the bottom part of the ignition barrel which has the wires as it has a fault and won’t operate the starter so I have had to temporarily use a bypass switch.
thanks for any help given.
Craig of the Sheffield Cortina Centre will probably be along to help you out with those bits.
Arms aren't sided which makes it easier & are same from mk3-5. I'll check but don't think I've any left.
For ign switch we need to know which colour/shape the plug is as you need the same one unless your good at soldering as it's only that part that differs.
There are two types of flat grey rubber plug, then a grey & a black square plastic plug.
A switch is no prob but will depend if I've one with correct plug.
Sent you a message. Not usually online till after 9ish pm
Think I have a wishbone somewhere.  Let me check next time I'm up in my garage
Is this what you need?
