MikeC
2000E reverse light switch
Has anyone got any idea's for replacing the little brass reverse light switch on a 2000E box. Maybe someone has found an alternative ? as I have not been able to find one, any help gratefully appreciated.
I bought one off ebay for a Mk3/4/5 Cortina when I first got my Mk3 but I had to trim back the bit inside that divides the rubber plug or socket (as it is) into two halves to make it fit.
Edited by Beeper
Do you mean a  2000E MK3 or a 2000E box (3 rail box Mexico, Corsair,etc)?
Former is fitted to escort RS1800/2000,MK2 Mexico only, all 1.3-2.3 Capri,Cortina(MK3/4/5/p100),Granada 2.0(ohc) 2.3/2.5 V6
4&5 speed manual.
The later Capri/Granada 2.8/3.0 V6,Corsair V4,MK2 Cortina, MK1 escort RS1600/TC, Mexico only.
4&5 speed manual.
Sorry i should have said  1968 mk2 cortina with 2000E box in.
If it's a 3 rail 2000E with swt on bottom it should I believe be the lower one on list,if it's the single rail version then with it on side  it's the top one.
On 12/16/2019 at 7:35 PM, sebspeed said:
one on ebay,number 254444520564
yep thats the one
35+ years of working on this stuff!
20 hours ago, brian c said:
I have seen that one but the wires have been changed and re soldered and I am worried the plastic bit of the switch may be damaged.
It might be worth a message to the seller - the way I read that is the other end connectors which now have bullets on them . The soldering on the switch end looks pretty standard to me . Steve.
it could be a long time before you get to find another
Or maybe not as he does say "rewired" !! still easy to test and if it doesn't work you can send it back .
I am chatting with this guy and might give one of these a go.
https://lotusmarques.com/parts/datasheets/299-fordlotus-gearbox-reverse-light-switch
bottom of the page
https://lotusmarques.com/parts/catalogue/lotus/47-elan-2-parts/277-lotus-elan-2-gearbox-parts-4-speed
Edited by MikeC
