swcortina
Mk3/4/5 parts for sale
18mm front anti roll bar with chassis brackets £40 NOW SOLD.
Estate rear hinge and torsion bars set up £20
Pair of mk3/4/5 rear lower arms (from mk3) £20
12mm rear anti roll bar £20
Various behind dash heater/air flow pipes from fl mk3
Pair front hubs £70
Pair new rubber front lower arm bushes £10
1600 rear axle £120 (collection only)
1600 gearbox £80 (collection only)
Pair front springs £20
Pair rear springs £20
All plus postage unless collection only.
Edited by swcortina
19 hours ago, Kencrackfixer said:
Hi
Do you have the bolts and spacers for the anti roll bar ?
Front or rear arb?
Do you need a full kit or everything except the bushes
Think I can help either way.
51 minutes ago, Kencrackfixer said:
Front
The bolts that attach to the lower arm
The ones like this?  Linky
1 hour ago, Kencrackfixer said:
Front
Got some used bolts with washers and spacing tubes, no bushes.
Mk3 steering column  £40 plus p&p
Now sold
Edited by swcortina
1600 pinto gearbox, some bell housing bolt holes damaged £60
Edited by swcortina
On 1/4/2020 at 7:58 PM, Kencrackfixer said:
Thanks
The linky thing did the trick
I spoke too soon !
When they turned up ,not as thick as the originals.
So still after the bolts and washers if available
cheers ken
I spoke too soon !
cheers ken
Those reproduction/aftermarket bolts are just a standard M8 bolt.  The original bolts were a type of shoulder bolt with a standard M8 thread and 13mm AF head but with a fatter main body than a normal bolt.  The original spacers and washers had a larger inside diameter to accommodate the shoulder bolt which is why if you use them with the aftermarket bolts then the spacers and washers don't fit snugly to the bolt.
Sounds like you're looking to source originals but they're going to be difficult to find as even any cars being broken for parts are likely to have had these link bolts replaced at some point in their lives and probably with the narrower bolts.
14 hours ago, Kencrackfixer said:
I spoke too soon !
cheers ken
I'll dig you out a set Ken.
Mk3 GT/GXL centre console gauges, one has a small burn hole in the bulb holder. £25
Edited by swcortina
