lowtina
Mk4 mk5 2 Door Opening Rear Windows
Hi all. I'm fitting opening rear windows from a taunus to my mk5 2 door. I've managed to get the majority in there but I have a question about the rubber hinge plugs. Has anyone messed about with 2 door opening windows??
Question is, plugs are wedge shaped and a pig to slip into the slots on the b post. When you then push the tags of the window into them, they slip straight through the slit, into the b post! If I put them on the window first, there's no way they'll go in the slot! Any ideas?
Lube the hinge to help it slide in  ooo matron!
It's a few years since I did mine but I seem to remember getting the ole Vasalene out :biggrin:
I used washing up liquid to get the rubbers into the B post. Since lube does seem to be the answer (matron), I'm going to try leaving the washing up liquid to dry, the vaselining the window into the rubbers! Thanks all, wish me luck. And sorry to all the disappointed google searchers that have ended up here!
Try to get the rubber as cold as you can
then get your ky on the metal bit of the window  and insert
:blush:
Washing up liquid contains salt and will cause rust on any bare metal . Read this on another post about putting a widescreen in  , a lot of people use washing up liquid but someone said about the salt in it . Googled it and it evidently contains salt as a thickener otherwise it would be runny like water .
WD40 or something similar, l was going to suggest KYJ, just don't force it.
That's true. And that's why I used Vaselene.
Please sign in to comment
Sign In Now
