Tony - Barking
Hazard & Heated Rear Screen Switches
Hello,
Has anyone got the hazard and heated rear screen switches with the connectors for a preface lift MK3 Cprtina?
i have 2 pair of switches but can’t get the cable connections.
Happy for just the connectors on any pair or a complete set if you have them.
Thanks
Hi Tony,
              I have a pair of swiches with the Round Pins same as the one at the bottom of your lower picture.
Cheers
Steve
Hi Steve,
Thanks for getting back to me.
Do you have the connector plug  for these?
 The top ones with spade terminals are very late Mk5,MK3 escort. By the other pair are MK3 facelift onwards.
MK3 preface lift are completely different & unique. The hazards are very hard to find,hrw bit easier.
Will check but think I've a full hazard set up but only a hrw swt.
These are the preface lift ones the hazards is complete ( will have a relay somewhere it's just STD 3 pin) it all plugs into original loom, but as I thought I've only got a new switch
Thanks Craig,
Mine is a facelift, I’ve had a chap come back to me who thinks he has the correct switches with connectors.
Thank you sir.
Ah you said preface lift at top. I've loads of facelift switches will check on loom parts.
No luck on loom parts as there part of loom I think I might have found the wire that runs from front to rear for the.
