RichardJ 59 Posted May 23, 2020 Just wanted to get an understanding of where tyres typically rub on the Cortina when the size and offset is wrong. I've seen a lot of mk3 with tyres that don't look like they will tuck under the arches on a hard corner or bump, and normally the front seems to sit higher to compensate. Is it always the front wheels that rub on the arch lip? Does the back end not have this problem? Share this post Link to post Share on other sites
GhiaMk4/5 207 Posted May 23, 2020 Had 8" X 15 with 195 50s under mine, just as an experiment. (Mk5) But I'm a firm believer Ford got it right with the Ghia alloys and 185 tyres. Your main concern is wheel off set, 7 X 13 with 205 60s would fit, just depends what look you are after?? Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted May 23, 2020 (edited) I've had the fronts catch on the upper centre on full lock & full compression (at same time). Same on full compression on the rears (not while cornering) but was probably the offset rather than actual tyre size. Edited May 23, 2020 by sheffieldcortinacentre Share this post Link to post Share on other sites
Beeper 85 Posted May 23, 2020 (edited) I had 185/70/13's on my 76 GT and going over a bump (didn't have the dreaded speed bumps back then) with 4 people in it (edit: not 4 people in the back seat) the back arches would just rub the sidewalls. Maybe it was due to the slightly shorter springs on the GT models, I don't know. Edited May 25, 2020 by Beeper Share this post Link to post Share on other sites
RichardJ 59 Posted May 25, 2020 Thanks for the comments guys. I'm trying to work out how wide I can get away with at the back. Not taking any chances with the front, but want as wide and dishy as I can with the back. If I space out my current tyres to the width and offset I want, there is plenty of clearance on the inside of the wheel, but not so much on the outside. When spaced out, if I put a large a spirit level on the outside of the tyre to see how far out it sits in relation to the arch, it sits about 5mm further out than the inside edge of the arch. So am worried if it bumps straight up tyre will hit arch and rub. On a corner it shouldn't be a problem as the live axel will tilt the wheels at an angle which should tuck them in clear of the arch, but a bump in the road may cause problems. Wasn't sure if there is any way round this, or if this is even an issue with how much the suspension travels on the Cortina, but thought I'd check out everyone else'e experiences with rubbing on the rear tyres. Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted May 25, 2020 Main catching point s outside edge from vertical travel, rather than cornering. Share this post Link to post Share on other sites
RichardJ 59 Posted May 26, 2020 Thanks Craig, yes this is what I was thinknig. If the wheels stick out to the inside of the arch, they will rub if the back end bounces up too far after hitting a speed bump or similar. But I see so many cars where the rear wheels stick out and fill the rear (and front) arches. How do these not rub, do these cars just have rock hard suspension? Share this post Link to post Share on other sites
Beeper 85 Posted May 26, 2020 You can go as wide as you like if you have a Jag IRS! Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted May 26, 2020 Yes either rock hard or have blocks to limit travel Share this post Link to post Share on other sites
brian grech 114 Posted May 28, 2020 Hi, its a very interesting topic which really concerns me. Would like to ask if 6x15 would be a no no for my Mk3 with 1inch lowered in the front and back. The free play between the rubber bump stop is very limited. the lower pic shows the ones i wish to buy. Any feedback greatly appreciated. Share this post Link to post Share on other sites
RichardJ 59 Posted May 28, 2020 It is more tyre width and offset dependent rather than rim width, as you could fit a 185 tyre on a 5j rim or a 6j rim, and it would be the offset that determines whether it would hit the arch or not. Do you know what offset the 6j rims are, and what tyres you would be looking at? I collected some data from the various posts on here and on the MTOC and modelled what works and doesn't on a spreadsheet. You can pretty much fit any width upto a max 225 tyres (with 8.5j rims) on the back, and 205 tyres (with 7j rims) on the front if the offset is suitable, and have it fit "properly" under the arches. I'm still trying to figure out how some people get away with having the wheel stick out level with the arches. Which I just can't see working unless the they do what Craig says and basically incapacitate the suspension movement. Share this post Link to post Share on other sites
brian grech 114 Posted May 29, 2020 15 hours ago, RichardJ said: It is more tyre width and offset dependent rather than rim width, as you could fit a 185 tyre on a 5j rim or a 6j rim, and it would be the offset that determines whether it would hit the arch or not. Do you know what offset the 6j rims are, and what tyres you would be looking at? I collected some data from the various posts on here and on the MTOC and modelled what works and doesn't on a spreadsheet. You can pretty much fit any width upto a max 225 tyres (with 8.5j rims) on the back, and 205 tyres (with 7j rims) on the front if the offset is suitable, and have it fit "properly" under the arches. I'm still trying to figure out how some people get away with having the wheel stick out level with the arches. Which I just can't see working unless the they do what Craig says and basically incapacitate the suspension movement. Tyres i was going to put are 195/50/15. Thanks Share this post Link to post Share on other sites
J2S 178 Posted May 29, 2020 (edited) I’ve Run that size on my mk5 its is in the floor and I get no rub my mk3 have 185/60/13 on the floor no rub the backs are easy to fit loads of different offsets fit widths ect but with the front that’s another thing Ive never seen a 7/13 on the front sitting properly inside the arches and I’d love the super light look ! im going with 7 j on the back 6.5 on the front ford rwd offset Edited May 29, 2020 by J2S Share this post Link to post Share on other sites
RichardJ 59 Posted May 29, 2020 (edited) 3 hours ago, brian grech said: Tyres i was going to put are 195/50/15. Thanks By my calculations - you could get away with fitting an offset as low as ET25 with 195 tyres and it still give you (a few mm) clearance to the inner arch lip on the front, although this would be marginal and if the tyre had any kind of sidewall "bulge" it could cause problems. I'd probably aim for ET35 as a minimum - this would move the outside edge of the tyre about 8mm further out than the Factory Sport 185 tyres on stock 5.5j ET38 rims. Should be pretty easy to get 6j rims that fit that bill, as any FWD Ford wheels should have an offset of ET35+ I think 13x7j superlights only come with an offset of ET-7 (i.e. negative 7), so with 195 tyres on the outside edge of the tyre would be 50mm further out than the factory Sport 185 tyres. That amount of offset would have absolutely no chance of tucking under the front (or rear) arch lips, so you'd have to "disable" your suspension somehow, or have the car ride with a 4x4 stance to get those to fit without carving up your wings. The tread would probably also only just be covered by the bodywork of the car meaning you'd be at the limit of legal - so you could probaly expect periodic Police attention. Edited May 29, 2020 by RichardJ Share this post Link to post Share on other sites
