RichardJ
Tyres and rubbing (mk3/4/5)
You can do the silly stretched tyre but I’m not into that I’ve got a pic somewhere of a set off 7x13 on a mk3 but it had such a stretch on the front the beads looked barely on the rim but they was under the arch
The silly stretched tyres craze is a MOT fail, my daughter has a T4 slammed on 8" rims at front with 195s and rears are 10" with 205s, to get it through a MOT it went on a set of standard rims, he knew as soon as it passed it was going to back on the stretched rims but for the time of test it ticked the boxes.
I've never understood stretched tyres myself,  but they seem to be a big thing in some parts of the VW scene.
Modifications should do one of three things in my view:
- improve one (or more) characteristics of the car;
- improve the appearance of the car; or
- help the car comply with legal/safety requirements
I don't think tyre stretching does any of those, and arguably does the exact opposite of each point.
  • Like 2
I look at a stretched tyre and think, well that's the side wall up the creak, and sooner or later it's going to be grief.
It's bad enough having proper size tyres on your motor and when they give up the ghost it's entertaining, I have had 2 sudden punctures in the space of 12 months, a stretched tyre is going to be brown underwear for sure.
On 5/23/2020 at 7:43 PM, GhiaMk4/5 said:
Had 8" X 15 with 195 50s under mine, just as an experiment.  (Mk5) But I'm a firm believer Ford got it right with the Ghia alloys and 185 tyres.
Your main concern is wheel off set,  7 X 13 with 205 60s would fit, just depends what look you are after??
Hi peeps contacted Image wheels for the rims below and he told me the et is 20. He suggested 6x15 and 185 tyres  instead of 195 so that i have more clearance. What are your opinions /issues i might have as those are the rims i want on my Cortina?Cheers
Have 185s on the front and the 195s on the rear,  l have a pro arch roller for when  my eldest was into slammed and stretched, pulled the back arches by a good 25mm, a lot of heat and gentle persuasion involved, the fronts were easy to do, more movement in then
Don't think you want to resort to those measures on your fantastic paint.
Thanks for feedback!
The picture isn't showing for me unfortuantely.
I can recommend Image though, my wheels are from there and I'm in the process of changing the inner and outer lips on them to maximise wheel size, which is why I started this post.
The standard Cortina mk3 Sport wheels are ET38 and also come with 185 section tyres, which makes the comaprison easier.
If you fit ET20s on you car, then compared to the Sport wheels you will be moving the mounting face of the wheel 18mm further inwards.  The outside edge of the tyre will therefore move outwards by about 18mm further.
It won't be exactly 18mm as the larger rim size will alter the tyre wall profile and "bulginess", but 18mm is a good indicator of what you can expect.
This is therefore going to be very marginal by my calculations (<2mm clearance), so is worth checking how much space you currently have between your current tyres and arch lip.
If you currently have the non-Sport wheels, I think these are 175s with the same offset, so your new wheels will stick out 23mm further than these.
As said above, rolling the arches gives a load more clearance, as the lip on the Cortina is pretty wide.
Edited by RichardJ
These are the wheels i'm after.
As said Image wheels are the dogs, liking your choice.
Here's another one to throw into the equation, did you know you can have two exactly the same size tyres, BUT by different manufactures and they are actually different dimensions, my son had 195 45 15s on his project, because he had lots of camber on the rear, he went for really cheap budgets, but the fronts were good quality and there was at least 10mm difference in width???
You're going for the same ones I have 😁
As they are multipart you have quite a few options regarding offset, which is what I am looking to play around with to maximize width at the back.
You could easily get another 12.5mm of positive offset on the ones you are interested in by increasing the inner barrel size by 1/2", but this would give you a 6.5j rim then - this is still the right size for a 185 tyre, but will be less baloony than on a 6j rim.
I had this problem on my other car.  Certain makes seemed to rub, whilst others didn't.
Like those too
They look FaBOULOUS!! Now i want them even more.Your car colour is very similar to mine.Did you buy them already?If so can you please tell me what size you went for? If i understood well you would go for a 6.5j rim? Cheers
Good to know .Thanks
Please sign in to comment
Sign In Now
