RichardJ
Ignition Switch (mk3/4/5) - the electrical bit
Hi
Does anyone have a spare ignition switch for a mk 3-5 that they would be willing to sell?
I'm after the actual electrical switch that mounts to the bottom of the barrel, not the lock and barrel itself.
Ideally a PFL mk3 one, but will happily take a later one if there are no PFL ones availble - I'll just need to get soldering.
Thanks
Rich
Hi Rich, I have this facelift (stamped 75) which I bought as a spare a while ago. Must admit I didnt pay attention to the wiring differences to my pre facelift one. I can now see how much shorter the cable is and different connections but as you say they can be re soldered. It appears to click and spring back correctly but cant meter it out as I dont know which wires do and should connect if correct.
If no one else has a pre facelift version and if interested pm me.
Pete
There's two wiring combinations on the plug of the pre-facelift.
Got both see pics.
Strange how they reversed the connectors orientation on them. Mine is the top one but has about a foot of cable between connectors and switch so different mod again?
Thanks for the replies guys - I missed them until now.
I'll need to take my steering cowling off and check which one I have, and will get back to you.
Cheers
Rich
