t.onyb
Front seat runner/adjuster/frames MK3
Hello,
Has anyone got the frames which the seats actually fix to?
I need both driver and passenger frames.
Thanks,
Tony
Should have some, if someone knows the height of the legs on the outers as I have some with 70mm back legs and 75mm front legs and some with 60mm front legs and 55mm back legs.
Can anyone confirm the correct size for the MK3 front seat runners?
Thanks,
Just measured my 72 GT 60 & 55.
Thank you Craig
Is Craig’s post any help with this??
Thanks,
Tony
It's possible that it's a pre facelift, facelift thing as I've not had any from a mk4 and mk5 have the seat belt catch attached to it. I have 1 of the lower rails and several of the taller.
Hi,
Not sure what you mean??
Mine is a facelift 1975 and the seat belt anchors with its own bolt.
Just wondering if pre facelift have lower seat rail than facelift. As most seats I've had have come out of facelift cars and I have more of the higher rails.
Speaking to various people and it looks like the lower rails are for pre facelift cars and the higher rails are for facelift cars.
Okay thank you.
Would you have these to fit my two front seats??
If you do, what would the cost be to post to me in London “IG11 OLG” area?
Thank you,
Tony
I could do a set of the taller rails with postage for £25.
