TIB3300
Wanted P100 Dash mount hand break linkage parts
Morning All
Am looking for a Cortina P100 handbrake set up /mechanism, I can get the cables its the linkage and pulleys am after
apart from the hand break its self.
If you only have a part of it, thats fine let me know  :thumbsup:
Of course you realise the P100 cable s to long for the car.
You need the second cross member & floor mounts the tube for bulkhead erc
 Cheers , would the front part not fit?
Yep but you need all the bits, you'll need to weld the tube to bulkhead ( similar thing to clutch one) & the adjuster bracket to tunnel, drill both bulkhead & dash to mount handle (different for pre-facelift to facelift & different handle/ mechanism to P100),get the cross member & weld it's mounts to tunnel then get the unique handbrake cable (rare only fitted to preface-lift base/L models for approx first 12 months) in the UK ( MK3/4 bakkies in SA & Australian mk3's with bench seat).
My cars a face lift, same as MK5s  I  thought using all P100 parts  would be the best way to go.
I have the MK5 P100 dash mout handbreak already, as I am going to have hydrolic clutch, I could use the clutch cable tube ?
Does anyone have a picture of an adjuster bracket to tunnel :thumbsup:
No as it's vertical. Other bracket is a simple L shape with hole to take cable .
Then there's a second crossmember with lever that rear cable attaches to.
