Dutboy 0 Posted July 15, 2020 (edited) Hi, Does anyone know of a pair of the larger M18 front calipers that might be available. These were fitted to the Mk3 2.0 estate and the P100. Any help or leads much appreciated. Happy to consider a pair in need of a build as well as ready to run. Thanks. Edited July 15, 2020 by Dutboy Spelling Quote Share this post Link to post Share on other sites
nogE 91 Posted July 15, 2020 Look up Big Red.... great units...i've had probably 5pairs.... and if you hv exchange their work out that part ex with u too http://biggred.co.uk/ Quote Share this post Link to post Share on other sites
Dutboy 0 Posted July 15, 2020 Thanks for the tip but big red recon calipers if you already have a set they do not have M18s in stock to sell outright. So I'm still looking for a set. I would also consider a set from a mk2 granada as these are the same but spaced for a vented disc. Can anyone help me source a set? Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 753 Posted July 15, 2020 Same as 2.0/2.3 mk2 Granada ( some 2.3 estates are vented). Quote Share this post Link to post Share on other sites
kenbex522 34 Posted July 17, 2020 You need to try the banger boys on facebook etc . Getting very hard to find now in vented or otherwise. Quote Share this post Link to post Share on other sites
Steve Walton 130 Posted July 17, 2020 (edited) A bit off the wall but would Capri 2.8i discs and calipers fit. The discs are ventilated. Edited July 17, 2020 by Steve Walton Quote Share this post Link to post Share on other sites
martog 149 Posted July 17, 2020 (edited) 33 minutes ago, Steve Walton said: A bit of the wall but would Capri 2.8i discs and calipers fit. The discs are ventilated. Yes, straight fit. You need space the caliper slightly using a 5mm washer between the hub and caliper and use longer bolts ( i used the tie bar to lower wishbone bolts, if you have a spare set). Standard pads are fine and you need to lose the splash shield and the back. Also, you will need the longer pad retaining pins as well. Edited July 17, 2020 by martog Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 753 Posted July 17, 2020 (edited) But only same size pad, I use the Capri vented disc & Granada 2.8 vented caliper (M 18 again) pad is about 40% bigger & still fits inside 13 in wheel. Any kit that will fit (available) mk2 escort/ MK3 Capri (depending on wheel diameter) will fit a MK3/4/5. Also the rear disc kits for Capri atlas axles ( as used under escorts) will again fit when used in conjunction with a Sierra disc brake cable. Edited July 17, 2020 by sheffieldcortinacentre Quote Share this post Link to post Share on other sites
kenbex522 34 Posted July 17, 2020 I use the vented M18 cals on my Corsair with Capri vented discs. It is very tight clearance wise for Lotus rims, but I use ali hubs which push the wheel out just that extra bit. I also have a remote servo which reduces pedal effort so the brakes i feel are pretty damn good and on a par with the modern cars i drive. Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 753 Posted July 18, 2020 I've run the setup on several mk3's with STD & aftermarket wheels . On my MK3 GT for 30 years & half that with the 302 V8 I've run with mk3-4 escort solid discs on the rear with Sierra/Granada rear calipers. With gen MK3 Cortina RS 4 spokes. Quote Share this post Link to post Share on other sites
WS1 13 Posted April 2 Probably way way way gone but ive just noticed a pair listed wrong on ebay (ive let him know) https://ebay.us/m/jbP3SX Quote Share this post Link to post Share on other sites
WS1 13 Posted April 2 They are listed as type 16 but they take the bigger pads.... im sure these are identical to my old xr6 ones Quote Share this post Link to post Share on other sites
Dutboy 0 Posted April 2 Thank you for the tip. I have since gone down the route of RX7 4 pot callipers and pads mounted using custom machined adaptors gripping on BWM 3 series 260mm vented discs machined to suit the Hubs and mounting bolt PCD. Which fits nicely under my 15" rims and stops the car very nicely. Quote Share this post Link to post Share on other sites
John Mack 337 Posted April 3 18 hours ago, Dutboy said: Thank you for the tip. I have since gone down the route of RX7 4 pot callipers and pads mounted using custom machined adaptors gripping on BWM 3 series 260mm vented discs machined to suit the Hubs and mounting bolt PCD. Which fits nicely under my 15" rims and stops the car very nicely. What engine/power do you have that needs the above please !? Any pictures ? Quote Share this post Link to post Share on other sites
Dutboy 0 Posted April 4 The need for better brakes was not driven by engine power in this case, although the engine is a 2.0 pinto built for torque with FR30 cam, over bored pistons and higher compression. The vehicle is a 1990's Eagle RV kit jeep which uses the suspension and drive train from from a MkIV Cortina. Its running 4x4 off road style tyres which are bigger and heavier than the standard Cortina wheels and tyres and have a greater flywheel effect especially at higher speeds, which when coupled with the fact I tow trailers with the vehicle, meant I needed brakes that had a greater grab, better ability to arrest the rotational energy and better ability to dissipate the heat generated which the set up I now have does. Quote Share this post Link to post Share on other sites
