phorbiuz
Mk3 carb
Long shot, but I'm looking for a known good carb for a mk3 1.3.  I need to test my theory that my carb is causing my running problems.
Can't help, but l have a NOS carb on my 1500 and it runs like a right pig, I've experimented with the timing and adjusted the carb and just when you think you have it right, it goes and throws a dicky fit, so  I'm thinking along similar lines as you.
Hope someone can help you.
Getting hard to find but same across the ford range.
Might be going to a jumble sun will see if any there & get details.
Thanks both, especially Craig for keeping an eye out.
Plugs, leads, coil, points already changed.  Only thing someone pointed out to me yesterday is to consider the dizzy as well but I'd prefer to start with the carb.
