Keiths Cortinas 4 Posted August 14, 2020 I intend to fit a Type 9 5 speed box into my MK1 Cortina using Retro Fords bellhousing mated to a 1600 GT Crossflow with Clutch kit. Is there a Prop shaft i can fit that will bolt straight on or will i have to have one made up ? cheers K Quote Share this post Link to post Share on other sites
the-ford-cortina.com 226 Posted August 15, 2020 I think you will have to get one adapted , you need the gearbox end to be from a type 9 / cortina auto or 2ltr mk3/4/5 and the diff end same as the original from your axle -+ right length - someone may know the correct length . find a prop the right length ( or longer and send them the correct measurements ) and those parts and send them to a prop refurb company to build you one up . Quote Share this post Link to post Share on other sites
Keiths Cortinas 4 Posted August 15, 2020 Yes , thought so , Thanks very much for your reply . Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 767 Posted August 15, 2020 Some used to use a 1600 avenger I believe. Quote Share this post Link to post Share on other sites
kenbex522 34 Posted August 16, 2020 Get the measurement from the box oil seal and diff pinion and give Neil at 105speed ring on 01234 826827 office hours. They have them made up new. Quote Share this post Link to post Share on other sites
Beeper 85 Posted August 17, 2020 On 8/15/2020 at 10:37 PM, sheffieldcortinacentre said: Some used to use a 1600 avenger I believe. When was the last time you saw an Avenger outside of a Marvel film? Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 767 Posted August 17, 2020 Know a couple of people with them although lost contact due to the Toyota virus. Quote Share this post Link to post Share on other sites
Beeper 85 Posted August 18, 2020 HaHa. Nothing wrong (fingers crossed) with my Toyota. Well, it's 18months past its' last service but other than that........ Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 767 Posted August 18, 2020 Rice burner will run forever. 1 Quote Share this post Link to post Share on other sites
