t.onybaldwin@yahoo.co.uk
Kick plate trim clip ??
Hello,
Has anyone got any of the trim clips that hold the footwell kick plates in place??
Mine are a tan / light brown colour, I think beige is too light.
I’ve added pictures to give an idea. I need 4 but a couple spare would be great.
Thanks,
Tony
Founds 4 if still needed?
Great glad I could help.
Craig,
Bit of an odd ball mate, but would you have any of the clips that hold the extended door handle bit on the GXL or 2000e??
I think you slot the bar in then screw in the actual handle??
If not do you have a picture of what I need??
After 4 - one off each handle.
Thanks you.
Do you meen that's inside door behind door card? Then yes have a set will sort a pic shortly.
These are the ones for the 2000E/MK4/5 Ghia armrest/door pull.
The GXL's have the briefcase handles which are similar to the tabs that the self tapping bolts go into.
Yes I want the arm rest clips that are behind the door card.
if these are the ones then yes please. Would you also have the screws to hold them in place?
Thanks,
Tony
Should have.
