Mk2 Crayford 5 Posted October 26, 2020 Whilst I'm ripping the car apart over the winter I want to sort out the wipers. Mine don't self park, just stop wherever they are when I switch them off. They also stutter when in use. Any ideas what the cause is likely to be? I assume it must be the motor or the linkages that need a clean. Quote Share this post Link to post Share on other sites
Chriswitha1600e 0 Posted October 28, 2020 I don't know for sure but I guess there should be a park switch on/in the motor somewhere? Juddering could well be just a dry screen and sticky wiper rubbers. Quote Share this post Link to post Share on other sites
Lotuscops 73 Posted October 28, 2020 Juddering is normally dry screen or worn blades. The switch should have 3 blades (most replaced with a 2 blade) On the back of switch upright facing you :- Top left spade = Black to earth Top right spade = Red Bottom left spade = Black to motor Quote Share this post Link to post Share on other sites
Mk2 Crayford 5 Posted October 28, 2020 I'll pull the switch out and have a check on the wires. Mine is slightly different as I turned the washer pump into electric by fitting a push to make switch in the back of it so when you push the knob in it acticated teh pump. That was a few years ago and i must have been bored that weekend! Quote Share this post Link to post Share on other sites
