brian grech
Mk3 Burtonpower -1inch springs problems on hard braking
Hi, i'm having problems with one(don't know why the diver side is giving me problems) of the -1"springs from burtonpower on sudden braking and speed bumps. It is not staying in place and the ride high is altered so much so that the 13 inch rims/tyres rub on cornering and bumps. Everything is new as all of you following my thread for 5 years know. What is causing the problem as i have tried everything in vain?Help greatly appreciated as i 'm stuck on what's the solution. The pic shows the spring as it sits now -out off place
Some info;
-The spring is the right way round
-all bushes new
- all tightened as hard as i could
- the tie/rod stabiliser having the arb wasn't on this model but i fitted one with  arb -if that makes any difference
- tyres same size all round
--what else ....
Edited by brian grech
Some info;
-all bushes new
--what else ....
Why is it out of place ?
oooh! I see it now, it would appear that the spring is too wide at the bottom, cousing the spring to slip,
Do you have the original spring to size up against?
Edited by TIB3300
1 minute ago, TIB3300 said:
oohh!
If you look at the red markings i've done they are out of line, the bottom part should be nexto to the raised bit of the wishbone
Just took some pictures on mine for you
Edited by TIB3300
Thanks Tibbs thats the way they should be seated, sometimes i think that burtonpower hve their springs not right,as in diameter,thickness of coil
yes i have the original rusty ones to check with. Thanks again i really appreciate your help as i'm giving up!
I think Miss J aka Danish, has issues with burton springs
As you said i will check the diameter as i think the bottom might be bigger and thus subject to free play
Make an L bracket coming off your anti roll bar bolts to keep the spring in situ, or weld a sort of u clamp onto the bottom arm that will lock the spring in place, not ideal, or back to standard springs.
Another idea, a lot of springs sit on a rubber pad, would mean dismantling your suspension to get one in, unless you split it and fed it in under the spring. I know from experience the 3/4/5 springs are under a lot of pressure, so you shouldn't really be getting this problem, perhaps a build up of painted surfaces not allowing the spring to grip metal to metal so to speak.
Probably more poor quality (cheap crap to boost profit margin) from Burton as usual.
Short of heating & bending best bet would be to weld a thick flat piece of metal to arm to keep spring from moving outwards.
I’ve had one set from them ,one spring was a different poundage from the other
and another set was so stiff they hardly moved !
What rubber pad would you use?Thanks
Have been told that by another guy on fb, how did you check the poundage please?Thanks for feedback
