johnny boy 159 Posted August 21, 2021 Well............... The repaired under dash wire loom is back in , and all conected up, converted to alternator , as the dynamo and reg were missing, and I had an alternator on my MK1 x flow , that im not using. Had to repair some wiring on the inner wings, but all sorted. The carbutettor spindle is siezes up , so thats off now , for a free up and carb clean. I did get it started and running on easy start, all all sounded good , so it wasn't put in the barn 30 years ago because the engine was duff. Not sure about the gearbox yet, as I can't drive it yet. Sheffield Cortina centre supplied me with a S/H gear lever, because the one on the car, the ball had dissapered, do they brake up ? Any way thats the latest up date, more soon Quote Share this post Link to post Share on other sites
nascar66 74 Posted August 21, 2021 Good to hear you're still making progress on the MK2 Johnny. Fingers crossed for the gearbox. Quote Share this post Link to post Share on other sites
mr Costin 56 Posted August 25, 2021 (edited) Never was in a barn, it was on a lawn... Swedish reg started with E and part of VIN is 777, correct? Off the road since 1989. Edited August 25, 2021 by mr Costin Quote Share this post Link to post Share on other sites
johnny boy 159 Posted August 25, 2021 That's the car Mr costin 🤔 I'd like to know some more Swedish history, even of it wasn't in a barn, and in a weather beaten muddy field😃 what do you know ? Quote Share this post Link to post Share on other sites
mr Costin 56 Posted August 25, 2021 Well, not a lot, I will ask my friend that saved it years ago. But what I do know is that my friend never ran the car just took it away from a farm where it had been for many years. I get back when I have talked to him. Must say it is very nice to see it went to a good home. We tried to advertise it here but nobody else but the Essex guy replied. Pic I inserted was a cople of weeks after the car was out of the barn! Quote Share this post Link to post Share on other sites
johnny boy 159 Posted August 25, 2021 13 minutes ago, mr Costin said: Well, not a lot, I will ask my friend that saved it years ago. But what I do know is that my friend never ran the car just took it away from a farm where it had been for many years. I get back when I have talked to him. Must say it is very nice to see it went to a good home. We tried to advertise it here but nobody else but the Essex guy replied. Pic I inserted was a cople of weeks after the car was out of the barn! That's good to know some info. I'm currently recommissioning it , so it can be used again. There is a few parts missing, that I'm collecting and repairing as I go, l have started the engine , and it sounds very quiet , I'm guessing the 62,000 Kms is the true milage. I did find some Swedish coins in the "a" post 😀 Quote Share this post Link to post Share on other sites
mr Costin 56 Posted August 25, 2021 What parts do you need? Maybe I can help you. Quote Share this post Link to post Share on other sites
johnny boy 159 Posted August 25, 2021 The Swedish specific item I needed was an ignition switch, for the steering lock, as it burnt out along with the wire loom, but a guy on oldskool ford sold me one . I,m coming across parts needed as I find them, at the moment , I am ok thanks , but it would be nice to be able to contact you for parts that are specific to the Swedish cars.👍 Quote Share this post Link to post Share on other sites
johnny boy 159 Posted August 28, 2021 I had some time working on the car today. The car had no clutch hydralics when I bought it, so I bought some seal kits from the club, and attempted to fit them last week. The slave cylinder,was siezed solid in the gearbox, I tried every thing to get it out, but it was not having it. In the end I had to destroy it, and air hammer it out. So I had to buy a new slave. Then I removed the master to rebuild that, but the piston was siezed in the bore, tried soaking in wd40, heating and cooling, but no good. So then I had to buy a master cylinder. So I put them on today , and bleed them, so I now have a opperating clutch. I could not get the car to restart today, after looking I found lift pump was not pulling fuel up from the tank. I removed it and found the diaphram push rod siezed, I freed it off, refitted it , and sucked the fuel up though it , and it now draws fuel from the tank. But now the accelerator pump diaphragm is leaking , so I need a new one of those. Any way its getting there slowly. Quote Share this post Link to post Share on other sites
johnny boy 159 Posted September 12, 2021 Well the lift pump didn't last, so I've ordered up a diaphragm kit, also had to fit a new carb pump diaphragm 🙄. While I'm waiting for the brake caliper s , I had time to make up an exhaust system , 2 inch straight through, all stainless , apart from the over axle part.😃 1 Quote Share this post Link to post Share on other sites
johnny boy 159 Posted September 20, 2021 I fitted new Flexi brake hoses this weekend, as the old ones had collapsed, and didn't pass fluid, although externally they looked serviceable.🙄 Quote Share this post Link to post Share on other sites
nascar66 74 Posted September 20, 2021 Nice work on the exhaust! Quote Share this post Link to post Share on other sites
johnny boy 159 Posted September 22, 2021 I've fitted the lift pump diaphragm, and it now starts and runs, and will also start 3 days later, so the pump is now drawing fuel up ok. I've fitted the gear lever, thanks Sheffield cortina center. And the calipers and discs arrived from tinman, thank you. So now it's on to some welding next I think. 🙄 Quote Share this post Link to post Share on other sites
johnny boy 159 Posted September 28, 2021 Underside of the strut tops, are very good, as are the tops. No welding needed here. Needs welding in a couple of other places 🙄 1 Quote Share this post Link to post Share on other sites
johnny boy 159 Posted September 28, 2021 I started the welding marathon this evening. A hole in the rear of the sill , turns into a big price to let in , and the inner dill to repair first, do there is something to weld the outer to.🙄 Quote Share this post Link to post Share on other sites
