johnny boy
Swedish lefty MK2 series 2, 2 door
Well...............
The repaired under dash wire loom is back in , and all conected up, converted to alternator , as the dynamo and reg were missing, and I had an alternator on my MK1 x flow , that im not using.
Had to repair some wiring  on the inner wings, but all sorted.
The carbutettor spindle is siezes up , so thats off now , for a free up and carb clean.
I did get it started and running on easy start, all all sounded good , so it wasn't put in the barn 30 years ago because the engine was duff.
Not sure about the gearbox yet, as I can't drive it yet.
Sheffield Cortina centre supplied me with a S/H gear lever, because the one on the car, the ball had dissapered, do they brake up ?
Any way thats the latest up date, more soon
Good to hear you're still making progress on the MK2 Johnny. Fingers crossed for the gearbox.
Posted (edited)
Never was in a barn, it was on a lawn...:cool:
Swedish reg started with E and part of VIN is 777, correct?
Off the road since 1989.
Edited by mr Costin
That's the car Mr costin 🤔
I'd like to know some more Swedish history, even of it wasn't in a barn, and in a weather beaten muddy field😃 what do you know ?
Well, not a lot, I will ask my friend that saved it years ago. But what I do know is that my friend never ran the car just took it away from a farm where it had been for many years.
I get back when I have talked to him.
Must say it is very nice to see it went to a good home. We tried to advertise it here but nobody else but the Essex guy replied.
Pic I inserted was a cople of weeks after the car was out of the barn!:fro:
That's good to know some info.
I'm currently recommissioning it , so it can be used again.
There is a few parts missing, that I'm collecting and repairing as I go, l have started the engine , and it sounds very quiet , I'm guessing the 62,000 Kms is the true milage.
I did find some Swedish coins in the "a" post 😀
What parts do you need? Maybe I can help you.
The Swedish specific item I needed was an ignition switch, for the steering lock, as it burnt out along with the wire loom, but a guy on oldskool ford sold me one .
I,m coming across parts needed as I find them, at the moment , I am ok thanks , but it would be nice to be able to contact you for parts that are specific to the Swedish cars.👍
I had some time working on the car today. The car had no clutch hydralics when I bought it, so I bought some seal kits from the club, and attempted to fit them last week.
The slave cylinder,was siezed solid in the gearbox, I tried every thing to get it out, but it was not having it. In the end I had to destroy it, and air hammer it out.
So I had to buy a new slave. Then I removed the master to rebuild that, but the piston was siezed in the bore, tried soaking in wd40, heating and cooling, but no good.
So then I had to buy a master cylinder. So I put them on today , and bleed them, so I now have a opperating clutch.
I could not get the car to restart today, after looking I found lift pump was not pulling fuel up from the tank. I removed it and found the diaphram push rod siezed, I freed it off, refitted it , and  sucked the fuel up though it , and it now draws fuel from the tank.
But now the accelerator pump diaphragm is leaking , so I need a new one of those.
Any way its getting there slowly.
Well the lift pump didn't last, so I've ordered up a diaphragm kit, also had to fit a new carb pump diaphragm 🙄.
While I'm waiting for the brake caliper s , I had time to make up an exhaust system , 2 inch straight through, all stainless , apart from the over axle part.😃
