Knappers1966
MK2 Cortina Rear Lights
Hi all, does anyone know if the rear light cluster on the MK2 Cortina can be taken apart ? The inside of the coloured lenses is dirty and needs a damn good clean.....
just done a few pics to explain, sorry haven t cleaned the parts. first you have to remove the bezel which is held by two "clips" on the outer middle of the frame. you have to push the plastic rod carfully from behind, here is a pic of the genuine plastic fixing:
once the bezel is removed you can take off the lenses which are held by 3 screws each (red arrows show fixing of the bezel, yellow ovals are lense screws)
Ahh fantastic...thank you SO much. I'll give it a go sometime and let you know how it goes.....:thumbsup:
