TIB3300
Wanted MK2 Granada Front calipers
Ive decided to go with the Granada set up, as I dont have to re/ drill any discs.
Looking for Mk2 Granada 2,8 Calipers
Thanks
Think I have a pair somewhere.  Will need a refurb, let me check over the weekend
Thank you sir!  :thumbsup:
I wont buy anything in the meantime
Hi Tony, you may have already sussed the Granada set up on a Cortina, but i just wanted to remind you of my experience.
The Granada uprights/spindles bolt into the Cortina arms, but grow the track out wider (about 15mm each side if i remember right) and induce more negative camber.
The Granada hubs will fit Cortina uprights/spindles swapping around the inner bearings, with only slight track width increase.
If you are doing something different or have it all sorted ,please ignore my info.
good luck with it all mate :thumbsup:
Posted (edited)
You can bolt Mk2 Granny calipers to a Cortina upright
Edited by dgo
Thanks Cap!
Didnt know about the granny hubs bit,     :thumbsup: but as dgo says. bolt onto cortina
:thumbsup:
Yeah,if all you need is better brakes granada calipers fit cortina upright.
My info is more aimed at the need to change to 5 stud, BUT,it is metric 5 stud ford and not imperial UK/USA 5stud,there is a slight difference in PCD.
You should have PM with photo
:thumbsup:
Please check your inbox.  More photos
:thumbsup:
TIB you have another PM
