KELLTINA 6 Posted March 29 Has anyone got a mk5 saloon windscreen seal. Need urgently. Cash waiting. Would prefer nos but anything considered. Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 282 Posted March 29 Beware there are two size screens/rubbers for saloon & must be a matched pair! Quote Share this post Link to post Share on other sites
KELLTINA 6 Posted March 30 15 hours ago, sheffieldcortinacentre said: Beware there are two size screens/rubbers for saloon & must be a matched pair! Yes Sheff I'm aware mk3/4 and estates won't fit mk5 saloon. Do you have anything Sheff? Quote Share this post Link to post Share on other sites
dgo 47 Posted March 30 Craig's the expert here but I've always understood that there are two different sizes of Mk5 saloon windscreen glass which need a wider or narrower rubber surround so they fit the same sized opening in the car body, I think that's what he means above Hopefully he'll will pop by to confirm. Assuming that's right - you're looking not only for a fairly hard to find screen rubber but the right sized one for your glass! (sorry) Separately the Mk5 estate uses the Mk4 screen Quote Share this post Link to post Share on other sites
KELLTINA 6 Posted March 30 2 hours ago, dgo said: Craig's the expert here but I've always understood that there are two different sizes of Mk5 saloon windscreen glass which need a wider or narrower rubber surround so they fit the same sized opening in the car body, I think that's what he means above Hopefully he'll will pop by to confirm. Assuming that's right - you're looking not only for a fairly hard to find screen rubber but the right sized one for your glass! (sorry) Separately the Mk5 estate uses the Mk4 screen I knew that the mk5 estate and saloon front and side windows were different. However I never knew there were 2 different mk5 saloon apertures. Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 282 Posted March 30 Sorry should've been clearer there's 2 mk5 saloon sizes (aperture is same size but screen/rubber are different & must be a matched pair, its essentially UK triplex, European securit marked on glass)while Mk5 estate uses same one as all mk3-4's. It should be in the parts interchange list top of tech section. Quote Share this post Link to post Share on other sites
KELLTINA 6 Posted March 31 20 hours ago, sheffieldcortinacentre said: Sorry should've been clearer there's 2 mk5 saloon sizes (aperture is same size but screen/rubber are different & must be a matched pair, its essentially UK triplex, European securit marked on glass)while Mk5 estate uses same one as all mk3-4's. It should be in the parts interchange list top of tech section. Cheers Sheff Quote Share this post Link to post Share on other sites
