Lobby
Pinto vacuum valve
Hi, have all MK3s, Mk4s and Mk5s got a valve fitted in the vacuum hose for the timing?
Many thanks.
If you mean a valve in the vacuum hose between the carb and distributer, I don't think so?
Yes, that's the one. I was told the other day that most Pintos have one, maybe not Cortinas then.
I'm 99.9% sure mine doesn't.
Only late mk5's but never noticed any difference?  Probably got some if your really wanting one.
Do you have a problem?
The timing on my car is pretty much bang on now but a Ford technician said that one of the valves helps cure slight pinking under load.
I'm going to run it for a while without and see how much of an issue it is, he seemed to think the valves were a standard fit, but it sounds like only on the later cars.
Thanks everyone.
Yep 80's fitment.
Due to the absence of lead & other changes to petrol since cortinas where introduced I use timeing figures as a starting point until I find what is the best that these & any other "classic" is happy to run at.
