AndrewGT
Mk1 Steering box and Accelerator Pedal
Looking for the above for my LHD to RHD conversion. Column not needed.
Pedal assembly with brackets through to bulkhead.
Many thanks.
Pedal assembly is the same, only the accelerator pedal is different, and you can easily modify that.
Thanks, yes, the accelerator has a much longer rod which runs over to the passenger side. Did you make one up or go for a cable?
In the end I didn't use the original pedal box, and used a bias adjustable box.
I think I have one I made , that was a copy of a Lotus cable one.
Finding it may be a problem, but its stored in a box of bits I didn't use, that I'm slowly selling, when I come across them :biggrin:
