bugsntinas
Mk5 chassis
Is it possible to buy the rear section of the chassis for a saloon or are they get like hens teeth. Couldn't see them on motomobil.
Posted (edited)
Presume you meen the piece under boot floor? If so pretty common .
Yeah that bit :)
3 hours ago, Deano66 said:
Jesus that ain't cheap but yeah that's it. I think i migjt cut the one out of the scrap car and see what it is like.
Yeah,not cheap mate.
If the one on your scrap car is good,then it sounds like a plan.
Slight change but with the rear outter rear valance does it have a flange on each end that welds to the wing as mine doesn't and i can see a gap so wondering if it's just had a bad plate put over the original
No mate,mine hasn't & i'm sure the saloons don't.
They overlap the rear wing & are spot welded to the wing.
This how i did mine,i guess the saloon will be the same.
Ah ok. Makes it easier to remove later down the line
Yes all fit like that.
  • Like 2
