kevinsingh
Auto choke
Recently purchased mk5 with a manual choke (poorly fitted).. I am reverting it back to autochoke but cannot remember where the water hoses ran off from..
Flow and return to the autochoke housing….
Might have to  invest in the trusty Haynes
Thanks in advance…
U shaped hose coming out of the intake manifold to the autochoke. Other hose exits the A/C and goes the the bottom heater radiator outlet.
Hello martog....that's great ... do you know of I need correct hoses or do i have to make up something to attach on the bottom hose?
regards
I think I just used off the shelf heater hose, usually comes in metre lengths?
Thats all I used. It's about all there is !!
Funnily enough think I've a U shaped one.
Thanks guys …..
I am confused how to attach to the bottom radiator hose?…or am Have I got the wrong radiator ?
…….also do I need to find a tee piece off the inlet manifold..I understand 1 end to the bottom heater matrix and the other to the auto choke ??
regards
…..where would I find a U shaped hose to fit … I still confused..been looking on internet for diagrams or pictures to help me but nothing found…
As the others have said you could make your own up using the meter lengths.
Personally, I went for black silicone heater hose as you can buy that shaped U section that does the intake to A/C on it's own from Rally Design and does look a lot neater than trying to make a U section up to work around the carb.
Also used the silicone straight lengths to run the other pipe from the A/C to the heater and from heater to water pump.
This is how I've done mine. Pipe coming out of the A/C is just formed to make an S bend.
Posted (edited)
I meen I might have a U shaped hose of a scrapped cortina ( the one to connect auto choke to manifold) I'll check tomorrow.
that would be great thank you
that is a super picture and yes that makes more sense to me now...thank you
Thank you so far to your helpful and valuable advice so far ….
